1993 GMC C2500 intermittant hesitations after 2400 rpm
1993 GMC C2500
160,000 MILES • V8 • 4WD • AUTOMATIC
JOHNRHAYNES
  • 4 POSTS
My suburban runs good up to 2400 rpm in D (overdrive) but then after 2400 the tac intermittently jumps up 50 rpm and you feel a slight lag in speed. (so you kind of go pulsing down the road if over 66mph in Drive.) Doesn't happen at a lower gear and the same rpm.
454 engine with factory replaced trans at 60K.
Jan 24, 2008 at 7:23 PM
2CARPRO JACK
  • 11,533 POSTS
Is that a throttle body or port fuel injection? Has it been tuned up recently and if so what brand parts were used? sounds like it is ignition related if it jumps
Jan 25, 2008 at 3:19 PM
JOHNRHAYNES
  • 4 POSTS
[quote:ad746a6aa3="2CarPro Jack"]Is that a throttle body or port fuel injection? Has it been tuned up recently and if so what brand parts were used? sounds like it is ignition related if it jumps[/quote:ad746a6aa3]
I have throttle body. Seems strange that it runs so smoothly until it hits exactly 2400rpm and above. Then the 50rpm jump is at the same time you feel a slight reduction in speed. Lasts for a second or so and then drops back for a second or so etc.
Last tune up was maybe 6k ago and generic parts were used.
If you are cruising at 70 on level grade and the torque converter lock goes in and out, how much rpm change would there be in and out?
Jan 25, 2008 at 7:25 PM
2CARPRO JACK
  • 11,533 POSTS
That would be about the right amount for the lock-up. If you are giving it any throttle it shouldnt lock the converter, might go in and out of OD depending on the amount of throttle being given.What gets me is the reduction in speed,almost like an ignition misfire causing the tach to jump and the engine to lose a slight amount of power.By generic parts, I hope you dont mean Bosch platinum plugs or their wires.Try to stick with the OEM stuff, costs a little more ,but the ignition system is designed around the resistance in certain ignition parts.
Jan 26, 2008 at 7:54 AM
JOHNRHAYNES
  • 4 POSTS
Thanks. I'll let you know after I follow up on items mentioned. Thanks again.
Jan 26, 2008 at 8:58 AM
2CARPRO JACK
  • 11,533 POSTS
Hopefully leads us somewhere
Jan 27, 2008 at 8:50 AM
JOHNRHAYNES
  • 4 POSTS
Solution: total transmission rebuild. It's like having a new truck (I suspect better). No electircal or computer problem as it turned out, just a totally worn out transmission. Thanks again. John
Feb 1, 2008 at 6:46 PM
