1986 GMC C2500 cluch problems
1986 GMC C2500
15,000 MILES • V8 • 4WD • MANUAL
FOSTON247
i have a 86 gmc 3/4 ton with a 4 speed and i just got it awhile ago one day i was driving it and i was dumping the clutch and it wasn't shifting rightafter i was dumping the clutch then i would have the clutch depressed and put it into gear and i had to slam it in then when it would go in it would start moving then llater in the day some how my hydrolic line from my master cylinder to my slave got cut so i got a new line bleed it still had problems got a new master bleed in stil no ppressure in the clutch i am wondering if my pressure plate is sticking or somethin because i can drive it just not using th clutch
Jan 2, 2008 at 1:12 PM
JIMAKRIDGE
  • 4 POSTS
If the wet clutch doesn't seem to be working and you did bleed down the fluid ram shaft box that press
against the clutch rod to engage it ? pump the clutch to see if this rod is working or moving the clutch arm ? If so then you have a clutch disc or pressure plate problem and it would be wise to do a clutch job and have the flywheel grided to if it still
good, install throughout bearing,clutch disc,pressure plate,incert all new and then it will be good to good for many miles. The wet hydro clutches are not ment to pop and try to spin the tires et'al'. The fluid only supplies enough movement to operate the clutch for shifting use some wisdom in the matter.
Jan 16, 2008 at 6:43 PM
