timing a 1995 1500 TBI
1995 GMC C1500
NOS155
  • 16 POSTS
hi, is there any way to adjust the timing on a 1995 Z71 chev pickup?
Mar 7, 2006 at 2:43 AM
NOS
  • 320 POSTS
look on the lable under the hood if you don't have a flat top type dist yes you can set timing .there will be a connector at the back of the firewall which is tan with a black stripe un plug it star the truck i think it sets at 0 but check the sticker for sure loosen the dist adjust timing lock down reckeck if still ok shut off truck reconnect wire and your set . if it has the flat top type dist there are no adjustments it is fixed and controled by the computer hope this helps.(NOS)
Mar 8, 2006 at 11:57 PM
