tilt sterring wheel problems.
GMC C1500
DARTHLIAM
I have a 1988 GMC Sierra C1500 and the steering wheel is really loose at the area where the tilt is at. What would cause the problem and what can I do to fix it?
May 17, 2006 at 10:51 AM
LOSONE
  • 1,616 POSTS
You have loose bolts where the tilt area connects to the column. You can get to two of the bolts by removing the steering wheel, flex plate and turn signal switch. I have done a lot of them. Good luck
May 17, 2006 at 11:42 AM
