No Cruze
GMC C1500
RECO56
  • 4 POSTS
Hey ok i just got a gmc c1500 1995 and i put it on the scanner to check for codes and none came up only that brakes were applied???!!!! so we replaced the switch Still same thing Plus no Response to the ABS computer and tourge converter wont lock up cause computer thinks brakes on!!!>>
Oct 9, 2007 at 8:13 PM
BMRFIXIT
  • 19,053 POSTS
[quote:a2d412e0c6="Reco56"]Hey ok i just got a gmc c1500 1995 and i put it on the scanner to check for codes and none came up only that brakes were applied???!!!! so we replaced the switch Still same thing Plus no Response to the ABS computer and tourge converter wont lock up cause computer thinks brakes on!!!>>[/quote:a2d412e0c6]
which switch did you replace
and did you try to unplug the switch and test
good luck
Oct 9, 2007 at 8:36 PM
RECO56
  • 4 POSTS
no i did not try unplugging the switch if i did i would not have brake lights but is a good idea i changed the brake pedal switch pain in the ass but its got a new one and the brake lights do work and also i can hear the relay clicking when i step on the brake!?? please help
Oct 9, 2007 at 9:40 PM
BMRFIXIT
  • 19,053 POSTS
[quote:6d5db45a2b="Reco56"]no i did not try unplugging the switch if i did i would not have brake lights but is a good idea i changed the brake pedal switch pain in the *bad word* but its got a new one and the brake lights do work and also i can hear the relay clicking when i step on the brake!?? please help[/quote:6d5db45a2b]
are you sure you dont have two switchs on the padel
Oct 10, 2007 at 6:36 PM
RECO56
  • 4 POSTS
i looked and there is only one switch for the brake on this truck
Oct 10, 2007 at 9:42 PM
BMRFIXIT
  • 19,053 POSTS
on the vin # what is your 4th and 8th this
https://www.2carpros.com/forum/automotive_pictures/99387_Image_3.jpg
Oct 10, 2007 at 9:54 PM
RECO56
  • 4 POSTS
#4 is E and number 8 is K
Oct 10, 2007 at 10:22 PM
BMRFIXIT
  • 19,053 POSTS
try this
https://www.2carpros.com/forum/automotive_pictures/99387_Image_4.jpg
Oct 11, 2007 at 8:23 PM
