My left brakes stick...
GMC C1500
SCHAFFER1231
I drive a 1988 GMC 1500,2-wheel drive, it has a little over 200,000 miles on it, it has an automatic transmission, and it's a 350 V8. The front left brake has been sticking so I replaced the calibur, rotor, and brakes. I also bleed the brakes system and there's no air in the brake lines. It still continued to do the same thing so I replaced the master cylinder as well, yet nothing has made a difference. When driving the truck if I hit my brakes the front left brake sticks and if you press the release valve it lets off, so for some reason it won't release the break unless I get down there and manually release. There is a burning smell on the tire and surrounding areas. I haven't experienced any fluid leaks. I haven't owned the vehicle that long, but ran well when purchased and haven't had to do any other work on it other than replace the starter.
Oct 21, 2007 at 6:08 PM
ADAMJOYDAY
Replace all your hoses, the hose has probably collapsed inside and is working as a "check valve".
Feb 22, 2009 at 7:46 PM
