Lack of Power and hissing
GMC C1500
TXDOMINO
I have a 1995 Pontiac Grand Am SE at over 150000 miles. About two weeks ago I noticed the car lacked some power when I pressed on the gas pedal. It seemed to get worse each day. It would be hard to accelerate after stopping at a light or climbing a ramp to the freeway. Then I began hearing a hissing sound. The hissing gets louder as the car was about to switch gears.. When it went to the next gear the hissing would go down until the next time the car was reving up to switch to the next gear. We first thought tha that it was the spark plugs and changed them and the fuel filter. But it just seems like it got worse... the last couple of days when i started the car.. the first 30 seconds or so the car does not want to move when the pedal is pressed.. then the engine seems to want to die. then the that problem solves its self and the good ol' hissing starts again.
Feb 20, 2006 at 2:11 AM
KENVCR
  • 105 POSTS
Did you check the condition of your exhaust system.
The catalytic convertor or the the muffler may appear good on the outside, however they do fall apart on the inside causing huge blockage.
Start your car and feel how much exhaust is coming out the tail pipe. Move your hand away and have someone rev it up. Observe the exhaust flow.
Just a sidebar, do you have a new air filter?
Your engine needs a good supply of air coming in and unrestricted flow going out.
Please post a reply if you work things out.
Feb 20, 2006 at 11:26 AM
