Clicking/Thumping Sound from dash
GMC C1500
MROMER
Whenever I turn the ignition key to the position where the radio comes on, I hear a clicking/thumping sound coming from the area of the blower motor housing under the dash on the passenger side. The sound lasts for about 10 seconds and then stops. When I turn the truck off, it happens again for about 10 seconds. The problem didn't occur often until I had the AC system recharged lately. What do you think the problem is? If I need to replace the blower motor, how can I remove the plasting cowling in front of it without cutting it out?
Apr 5, 2006 at 8:12 PM
MROMER
After feeling around underneath the blower and recreating the problem, I noticed that there is a white plastic vent with a black plastic grate that can be seen if you lay down on the passenger floor mat and look up towards the blower. If you push up firmly on the vent, the clicking noise will stop. I'm not sure if it's a vibration problem or what. I wedged the vent partly closed, and that stopped the noise. I also checked to make sure that when I unwedged the vent after about 10 seconds (when the sound normally stops) that it didn't start back (i.e. I wanted to make sure that I wasn't holding up a motor, which might heat up and cause future problems).
Not a scientific fix, but a fix nonetheless....
Apr 8, 2006 at 7:57 PM
GENO51769
I'm having the same exact problem with my 91 Chevy K1500. It has been driving me nutty. I can't believe it is that simple to fix. I figured I would be taking the whole blower out. Now granted I haven't yet tried what you posted but the symptoms sounds the same.
Aug 9, 2006 at 11:31 AM
Sounds like the blend door actuator is bad. This is a common issue with these GM trucks
See the guide below on how to replace it
Here's a video
https://youtu.be/Eqf-H3COtSo
Mar 4, 2019 at 6:41 PM
