Barking brake flashing
GMC C1500
BACK-N-BLACK
I have a 1990 GMC K1500 extended cab 4x4 with a 5.7 litre. My question is that my parking brake light started flashing. It will flash 10 times then pause then start all over. I did a complete brake job on it about 3 months ago includiing wheel cyllinders on the rear. The brake llight was stuck on for a couple of weeks, I figured it was the switch but did not have time to check it out. Then today it started flashing.
Any ideas.
Thanks :D
Rich
Nov 29, 2006 at 8:47 PM
MCCASLINE2001
  • 7 POSTS
[quote:736a60a6e0="back-n-black"]I have a 1990 GMC K1500 extended cab 4x4 with a 5.7 litre. My question is that my parking brake light started flashing. It will flash 10 times then pause then start all over. I did a complete brake job on it about 3 months ago includiing wheel cyllinders on the rear. The brake llight was stuck on for a couple of weeks, I figured it was the switch but did not have time to check it out. Then today it started flashing.
Any ideas.
Thanks :D
Rich[/quote:736a60a6e0]
Well I had the same problem with my truck and it ended up to be a broken E-brake cable pin. I had to reset the light at one point by disconnecting the positive battery cable for atleast 1 minute and then putting it back on. That just resets your entire vehicle's computer. Hope that helps.:D
Dec 13, 2006 at 7:57 PM
