!994 Chevy Truck ?
1999 GMC C1500
SHAKER
Driving down highway speedometer will jump back to zero and the truck seems to lose power for a fraction of a second then the speedometer will jump back up to the correct speed. I connected a radar detector into the cigarette lighter and when the speedometer jumped back to zero the radar detector reset itself meaning the truck lost total power and cut right back on. So apparently the whole truck is losing power for a split second. It does not do this at idle or slow speeds only moving down the highway.
1994 Chevelot 1500 Pickup
176,000 miles
Apr 10, 2006 at 2:17 PM
LOSONE
  • 1,616 POSTS
The ligter is an ignition off hot through a fuse. It sould like you should check you battery connections especially the grounds. Check the smaller red wire to a connector on the fore wall. They feed the truck. Check for loose or corroded connectors. Let me know
Apr 10, 2006 at 5:40 PM
