2004 GMC C1500 pedal will go to floor
2004 GMC C1500
47,888 MILES • V8 • 2WD • AUTOMATIC
SJIEERERFA
bleed all four wheels- no broken pads or shoes-no fluid leak- brake pedal usually is ok but always feels soft - can the vacuum change during low rpms or slow speeds
Feb 21, 2010 at 3:50 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
This may be a by-passing master cylinder, this is when the fluid by-passes the primary cup seal in the master cylinder with out leaking externally, this will give you a soft sinking pedal that will pump up hard again.
Mark (mhpautos)
Feb 21, 2010 at 4:15 AM
