2003 GMC C1500 Rough Idle
2003 GMC C1500
64,000 MILES • V8 • 4WD • AUTOMATIC
MLAUCK11
When I start my truck in the morning the idle is rough and it feels like it is going to stall out. I replaced the fuel filter did not fix problem. Once it is warm up the problem goes away. Any ideas?
Feb 2, 2008 at 10:59 AM
MASTERTECHTIM
  • 4,750 POSTS
these engine have problems with carbon build up. usually running high pressure injection cleaner through the fuel rail usually fixes it. you need a special set up to do this procedure. also you could have a bad coolant temp sensor.
Feb 2, 2008 at 11:13 AM
