Brakes problem
2000 GMC C1500 V8 Four Wheel Drive Automatic 48.000 miles
ONE BRAKE LINE EXPLODED FROM CORROSION , 3 OTHERS WERE LEAKING , THE REMAINDER 34" OF LINESWERE BADLY OXIDIZED AND DECIDED TO CHANGE ALL LINES,NOW MY MECHANIC IS UNABLE TO BLEED THE SYSTEM , THINKS THE ABS IS CAUSING THE PROBLEM BUT HE IS NOT SURE WHAT TO DO ,ANYONE HAS ANY TECHNICAL ADVISE OR WHAT THE SEQUENCE OF ACCOMPLISHING THE BLEEDING IS, I WILL APPRECIATE ANY TIPS!,GEORGE.
Mar 31, 2008 at 4:43 PM
