2000 GMC C1500 ball joint replacement
2000 GMC C1500
NTSMITH69
Suspension problem
2000 GMC C1500 V8 Four Wheel Drive Automatic 200k miles
to replace the lower ball joint. does the drive axle. spndle. tire rod. have to be removed. and i was told that these were pressed in but looking at the lower it looks like it is rivited in. the lower ball joint id the original one.
May 30, 2009 at 12:47 PM
BILLYMAC
  • 2,204 POSTS
hi loosen the ball joint nut from the spindle. break ball joint loose grind rivets off new ones have replacement bolts. you don,t need to remove anything else ,unless you want more room . thanks billymac
May 30, 2009 at 11:22 PM
NTSMITH69
tnxs for the reply. but there are no rivits on these and they have a snap ring and are pressed in. wanted to know if, in order to have enough room to press it out. these will not pop out like a bolt on type.
May 31, 2009 at 10:47 AM
