1999 GMC C1500 Oxygen Sensors
1999 GMC C1500
90,000 MILES • V8 • 2WD • AUTOMATIC
JWMILLER
I'm wondering if I can get away with only replacing the upstream or pre-cat sensors. My Suburban has 4, and is not experiencing any problems, except for lower fuel milage. I've read about the sensors and everything is telling me that the two upstream sensors are used to adjust fuel mixture, while the downstream ones measure the effectiveness of the Cat. Is it ok just to replace the upstream sensors? What problems might this cause?
Oct 13, 2008 at 1:36 PM
Hi:
Yes you can replace only the upstream sensors, and it will not cause any trouble. Make sure, however, that they are bad. Have them tested prior to replacing by having the computer scanned for trouble codes. Most parts stores will do it for free.
Dec 15, 2008 at 4:56 PM
