rear caliper mount bolts will not come out after loosening. is ther a trick to getting them out?
Sep 18, 2010 at 2:45 PM
TOMBSTONE87
MEMBER
if the bolt loosens up but fails to remove then the bolt is probably stripped or frozen in the slide try loosening the bolt while using a flare nut wrench smaller than the diameter of the bolt head and pull out while loosening
