1997 GMC C1500 noise
1997 GMC C1500
130,000 MILES • V8 • 4WD • AUTOMATIC
SCRANTONG
  • 4 POSTS
When I step on my brakes I hear a vacuum type sound, what could be the cause of that? Does it mean the brakes need to be replaced?
Aug 29, 2008 at 10:46 AM
BLACKOP555
  • 10,386 POSTS
can you describe what a vaccum sound is like? do you notice any decrease in the performance of the brakes?
have you noticed any issue wiht the performance of the vehicle?
does the sound you hear such as when the engien is off and you push on the brake pedal, is that the sound your hearing?
Aug 29, 2008 at 1:49 PM
SCRANTONG
  • 4 POSTS
I hear it both times when using the brakes and also when the car is shut off
Aug 29, 2008 at 2:02 PM
BLACKOP555
  • 10,386 POSTS
but what is the sound? i dont know what you mean by vaccum.
Aug 29, 2008 at 9:18 PM
SCRANTONG
  • 4 POSTS
Kind of like a hissing sound, even when I step on the brakes I hear it.
Aug 30, 2008 at 1:55 PM
BLACKOP555
  • 10,386 POSTS
you notice any decrease in brake performance as prevously listed.
the brake level still good?
Aug 31, 2008 at 3:38 PM
SCRANTONG
  • 4 POSTS
the brake is very hard to press, before I could press them and stop on a dime if needed. I need to put a lot of pressure on to press it down now. It is not always making the noise when I step on it. But when it does it kind of sounds like something letting air out.
Sep 1, 2008 at 9:46 AM
BLACKOP555
  • 10,386 POSTS
sounds like a bad brake booster or possible bad check valve in it.
which would explain the hard to push pedal and noise when pushing on the brake.
Sep 1, 2008 at 3:36 PM
