1997 GMC C1500
1997 GMC C1500
152,000 MILES • V8 • 2WD • AUTOMATIC
ANGELMAT4
i m getting a trouble code 1345 i replaced the camshaft position sencer but code is sitill there i was told if i hook up my reader and watched the rpm if it was off like maybe close to twice as much as it was it is telling me ithe cranksfaft position is bad is that so and is there any thing else i could try before i take to a dealer thanks for any help
Oct 23, 2010 at 7:15 PM
HMAC300
  • 48,601 POSTS
if your distributor is not in right it will set this code.align themark on the crank balancer with the mark on teh timing cover. make srure the rotor on the distributor is pointing to #1 if it's not move it there then clear the code and see if it's still on. If i is then test the engine on RPM and if the rpm's read double then your crank sensor has to be replaced.....if you fixed it originally and didn't clear the code you need to do that first.
Oct 29, 2010 at 5:38 PM
