1996 GMC C1500 rough idle
1996 GMC C1500
112,000 MILES • 6 CYL • 2WD • MANUAL
MPAPP
i have a 96 gmc pick up that died on me while driving, its not on the fuel related side i've checked all that. it starts up but it will idle really hard for about 5-15 seconds then die, i was wanting to know which part it could be that causes this? ckp sensor, egr valve, tps sensor, maf sensor, or maybe something different? ive also checked all of the distrib parts and ignition mod so its not that. keep in mind it died while driving and idles rough. thanks alot for any help
Aug 23, 2009 at 4:26 AM
DR LOOT
  • 2,311 POSTS
The first thing I would do would be to disconnect the EGR valve and see if it runs any better, then I would check the truck for a vacuum leak, most likely at the brake booster, how are the brake's? you can check it for a vacuum leak very simple, take a small propane torch and run it along the edge of the intake manifold, also check your throttle body, if it runs smooth. You've got a vacuum leak.
Aug 31, 2009 at 5:53 PM
