this vehicle started to "bumble" slightly the other day when towing my boat. the last time i had this it was much worse and turned out to be the dist. cap. that was about 18 mo's ago. i opened the cap up and it looks good. what concerns me is there is a ring just under the rotor,it is about 6 inches around and about 3/8 inch thick. it is loose, just sits there and can be lifted up and down slightly and turned about a 1/2 inch or so in either direction. is this part acting normal or is it broken? if broke does the dist. have to be replaced? thanks, dennis
Jul 17, 2010 at 11:42 AM
