1993 GMC C1500 need a answer please
1993 GMC C1500
135,000 MILES • V8 • 2WD • AUTOMATIC
CJ417
when appling brakes it shakes violently not a rotor i replaced inner and outer tie rods both sides could it be the ball joints
Aug 26, 2008 at 9:57 PM
BADBO
  • 35 POSTS
Did you check the idler arm and pitman arm. Look under the truck at them and have someone move the steering whell back and forth to see if you see any movement in either. Hope this helps To check ball joints place a flow jack next to the tire (inside)
raise it about 2 inches off the ground and with a bar
pickup on the tire and wheel to see if you see any movement. If so replace ball jpoint.
badbo
Aug 30, 2008 at 8:00 PM
