had to pull the intake manifold to fix water inlet. did not mark distributor!!!!. when putting back i set #i cylander up on comp stroke and mark appears tdc on pully and put distibutor pointing towards #1 tower. fianlly got it to fire but and run , barely runs , i move distributor but gets no better,rough, someone said i need to unhook wire and set timing then plug back in, computer ?? what and where is wire. i might be a tooth off but cant move oil pump ??? i need help, tim ing light is broke but should be able to get to run by ear to get to town to set a garage
Jun 4, 2010 at 11:14 AM
