1993 GMC C1500 Coil
1993 GMC C1500
166,000 MILES • V8 • 2WD • AUTOMATIC
ROBINTX
I have a problem where my engine will not start. I am getting power to the coil. But nothing out of the coil. I am not getting fire at all when I crank the engine. No fire on coil going to Distributor.
Any help would be appreciated.
Changed the coil and coil wire.
Thanks
Jul 4, 2008 at 3:11 PM
MASTERTECHTIM
  • 4,750 POSTS
replace the ignition module in the distributor and if that doesnt work you will need a pick up coil in the distributor but its most likely the module. good luck and let me know how you make out
Jul 4, 2008 at 6:23 PM
ROBINTX
Matertechtim, exactly the problem thanks a lot. It was driveing me crazy. I could grab the coil and no shock. Replaced the module started up no problem I appreciate your help.
robintx
Jul 5, 2008 at 6:01 AM
MASTERTECHTIM
  • 4,750 POSTS
no problem
Jul 5, 2008 at 5:11 PM
