1992 GMC C1500 Fuel Injectors
1992 GMC C1500
CHRISCOY
Engine Mechanical problem
1992 GMC C1500 V8 Two Wheel Drive Automatic
my fuel injectors are not getting gas.I checked my fuel pump its working fine. I checked my gas filter its
getting gas. Then I loosened the fitting to the Throttle Body its getting gas. it was running fine when i went to work i was idling then all of sudden it shut down it didnt make on noise like it was losing gas i tried to start it nothing it just cranks over
Dec 9, 2009 at 10:33 AM
JDL
  • 16,098 POSTS
welcome to the forum, when was the last tune-up? Use a gage and check fuel pressure. If fuel pressure is good,but, no injector pulse, I look for an rpm signal. Check trouble codes. I don't replace a pump without checking B+ and ground at the pump.
Dec 9, 2009 at 10:40 AM
