1990 GMC C1500 whistling sound when engine is hot and conti
1990 GMC C1500
20,000 MILES • V8 • 2WD • AUTOMATIC
BBEERBOWER
whistling sound when the engine is hot and continues
when in neutral. stops when I accelerate.
starts again when it goes back to neutral
engine is idling faster than normal when engine is hot
this is what I have done to correct this problem and nothing has worked.
changed serpentine belt
changed barings inside alternator
changed idler pulley
changed 90' on vacuum hose tip (end)
put starting fluid around hoses and under air filter to find out where the noise was coming from - couldn't find noise
thank you,
bbeerbower
Apr 29, 2009 at 11:10 AM
TOMBSTONE87
  • 9 POSTS
check your egr valve and egr valve hose and make sure the nuts are torqued properly
Jun 19, 2009 at 9:45 PM
