1987 GMC Sierra Classic 1500 Series ZLH 5.0 Engine
1987 GMC C1500
CARL STANLY
Throttle Body, Fuel injected, Vehicle designed for Principal use at low Altitude.
I live in North Eastern Pa. and the problem is that it Stalls when coming to a stop. Stalls when put in gear and also stalls at idle, other than this it runs great.
There is no idle adjustment, but I replaced the idle air control valve and it didn't solve the problem.
I'm really puzzled at what I can do to try and fix this problem, if you have any suggestions I sure would like to hear them.
Thanks,
Carl of North East Pa.
Apr 10, 2007 at 6:58 PM
Start with the EGR and fuel pressure then comeback
Apr 11, 2007 at 4:58 PM
CARL STANLY
I checked both the egr and fuel pressure and both are working properly. I put the truck in gear and it cuts out. Don't know where else to check to find out why it does this.It still cuts out when slowing down to a stop for a stop sign.
Thanks,
Carl
Apr 15, 2007 at 12:07 PM
[quote:399637d2fb="carl stanly"]I checked both the egr and fuel pressure and both are working properly. I put the truck in gear and it cuts out. Don't know where else to check to find out why it does this.It still cuts out when slowing down to a stop for a stop sign.
Check the coolant, throttle, MAP sensors-could be the ICM or crankshaft position sensor.
Thanks,
Carl[/quote:399637d2fb]
Apr 15, 2007 at 5:11 PM
