2007 GMC Acadia intake tunning valve stuck open
2007 GMC ACADIA
42,000 MILES • 6 CYL • 2WD • AUTOMATIC
UGANATIONALTITLE211
the code was j2070 on the check engine light and it said that the intake tunning valve is stuck open what does that mean and i am out of town is it ok do drive it back home another 85 miles or so.
Jun 22, 2009 at 10:56 AM
BRIAN 1
  • 1,030 POSTS
DTC P2070: Intake Manifold Tuning (IMT) Valve Stuck Open.An intake manifold tuning (IMT) valve is used to change the intake manifold plenum configuration. When the IMT valve is open, the intake manifold is configured to one large plenum. When the IMT valve is closed, the intake manifold is configured to 2 smaller plenums. The IMT valve improves engine performance at low and high engine speeds depending on the engine load. The IMT valve assembly consists of the following:
• A tuning valve
• A microprocessor
• An electric motor
• A hall-effect sensor
• An ignition voltage circuit
• A ground circuit
• An IMT valve control circuit
• An IMT valve signal circuit
this is the descripition,it should be ok to drive,but I would get it fixed ASAP.
Jun 22, 2009 at 1:38 PM
