2007 GMC Acadia How do you change out an HID Headlamp that
2007 GMC ACADIA
37,000 MILES • 6 CYL • AWD • AUTOMATIC
JOEYKON1
How do you change the low beam HID headlamp in and 2007 Acadia SLT model? Also what is the part number for the HID bulb. Last how do you change out the bulb for factory installed fog lamps on the same vehicle
Jun 10, 2010 at 10:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
jack the vehicle up and remove the tire
then remove the inner fender
there are 6-8 philips screws and 6 or so push pins
remove the inner fender then you will see the back of the head light there are 2 caps one is low beam other is high beam
remove the cap then turn the bulb counter clockwise to remove
replace the bulb and reassemble. sorry not certain what part number is on it, should be on the bulb though. should be able to access the foglights as well while you're changing the headlight bulbs.
Jun 10, 2010 at 10:18 PM
