New update: Problem resurfaced but slightly altered. ABS, brake light, and security light have been flickering on and off for weeks. I replaced the entire steering column wiring harness and pigtails associated with the ignition switch. No change. I change the ignition key cylinder. No change, however, when I got the cylinder re-keyed and I reinstalled it, the flat-gauge, all-lights problem manifested briefly before returning to the spastic abs/brake light vacillations. Could the antitheft security device be a factor?
Below I'm posting my full gremlin hunting saga as a recap:
• For years car has been plagued with intermittent and unpredictable electrical shorts manifesting when all the gauge lights light up and the oil, battery, gas, and temperature gauges all go flat.
• Recently this problem escalated with cluster and radio turning on and off, key getting stuck in ignition, inability to start car or shift out of park when car did get started.
• Also, but may not be related, rear wiper engages when brake is pressed sometimes.
• Previous owner tampered with wiring to install subwoofers. Not sure if fuse box under rear seat can contribute if it’s been messed with? Old subwoofer wires still connected there.
Attempted Solutions
• Had gauge cluster and sending motors refurbished twice. No change to problem.
• Had various mechanics check electrical systems, clean grounds, fix splices. No change to problem.
• New battery and bolts when terminals stripped. No change to problem.
• Replaced entire steering column wiring harness and pigtails. No change.
• Replaced Key ignition cylinder. Key hasn’t gotten stuck, but original problem still exists.
• Gauge-light-up-and-flat-gauge problem stopped briefly after having car worked on, but ABS, brake, and security light would come on and off unpredictably and very frequently accompanied by the odometer and gear shift indicator flickering when car vibrates from road. Battery gauge vacillates.
• Had alternator and battery tested by AutoZone. All tested good. Battery is only a year old.
• Replaced left wheel speed sensor and cleaned right wheel speed sensor. No change to ABS or brake-light flashing intermittently.
• Topped off brake fluid- no change to brake light problem. Fluid was flushed not too long ago.
• Cleaned ABS ground. No change to problem.
• Had ignition key cylinder changed by locksmith. When reinstalled, the gauge-light-up-and-flat-gauge problem manifested again after it had been absent for a few weeks and vanished before I could record it. Typical.
• Then day after locksmith, no ABS, brake, or security light even after a long drive. Only faint flicker of odometer/gear indicator light.
New theory
• Maybe antitheft device on ignition is faulty?
• Some short between fuse box and ignition?
• Vibrations from road affect odometer and gear shift indicator display suggesting a loose connection?
Aug 20, 2024 at 2:28 PM
