Glk350 engine block has a hole leaking what is the problem
2013 MERCEDES BENZ GLK 350
234,621 MILES • 3.5L • 6 CYL • AUTOMATIC
LUB
Glk350 engine block has a hole leaking what is the problem is
Dec 29, 2015 at 10:42 PM
CARADIODOC
  • 34,306 POSTS
You may find this hard to believe, but I can't see it from where I'm sitting. I can't see which engine you have either. Possible causes are coolant leaking from the weep hole on the bottom of the water pump and a leaking core plug. Beyond that you need a live person to look at it to see where the leak is occurring, if it's coolant or engine oil, and to determine what caused it and what is needed to fix it.
Dec 30, 2015 at 5:00 PM
