Getting the same code P0128?
2016 DODGE GRAND CARAVAN
162,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
PHOENIX357
I keep getting the same DTC Code on my van, code P0128. I have changed the thermostat as well as the engine coolant temperature sensor. Code was cleared after each repair. I also made sure the cooling system and heater core was bled after the repairs. I did a pressure test on the cooling system too and I didn't notice any drop in pressure, yet I have to add coolant every couple of weeks or so. I do not notice any white smoke from the exhaust upon starting or driving. The van has never overheated, and the heater produces hot heat in a reasonable amount of time. The entire engine bay always smells of coolant, yet I've never seen anything leaking. I know I must be missing something, but I can't figure it out and this is driving me crazy.
Nov 1, 2022 at 6:44 PM
Have you replaced the radiator cap? Also, have you checked to see if there is anything mixing in the engine oil?
Take a look through this link:
When you replaced the thermostat, did you install the entire assembly? The code is specific to the engine not reaching operating temp within a specific amount of time.
Nov 2, 2022 at 2:03 PM
P0128 engine coolant is below temperature which can happen when the coolant is low. I would use a flashlight to inspect the radiator fins and core. This can leak and evaporate making it head to see. Check out this guide, it may help:
https://www.2carpros.com/articles/car-is-leaking-coolant
and
https://www.2carpros.com/articles/coolant-leak-symptoms
Please go over these guides and report back.
Nov 2, 2022 at 2:12 PM
