ABS light on
2007 HYUNDAI SANTA FE
162,800 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
PWALDRIP
The error lights come on while driving a long stretch with cruise on at forty five mph.It has been highly intermittent and does come on at highway speeds with cruise on at seventy, seventy five, and eighty mph. Sometimes it will reset after vehicle is shut off refueled or lunch, and overnight. At other times the error lights stay on for a while. Have had system checked for error codes, none show up on system.
Jan 15, 2018 at 11:15 AM
Good morning.
There is a fault code stored in the ABS module. A parts store can read the code for you and it will narrow the area of failure. It sounds like a wheel speed sensor is a common cause. It sounds like you may have a wheel speed sensor that is out. These videos will help us find the problem.
https://youtu.be/rTtAnsOlZU4
and
https://youtu.be/Pb6nXV-iamI
and
https://youtu.be/ANWVTh2RQoQ
and
https://www.2carpros.com/articles/abs-warning-light-on-easy-repair-guide
Jan 16, 2018 at 3:32 AM
PWALDRIP
Thank you, will check it out and let you know. the lights are currently out. may have to wait until they come on again.
Jan 16, 2018 at 12:09 PM
Okay, we will be here. they can also still see the code in history.
Jan 16, 2018 at 4:50 PM
ROBKAYAKFISHINGGUY
I am fairly mechanically inclined worked on my cars except not much
knowledge on ABS systems.
First off started with when starting from a stop or in the morning
there would be a couple of clunks.. as if the transmission did not engage.
If I pushed the TOC button it didn't happen or (automatic transmission).
I put it in first or second gear "clunks" did not happen.
Then the brakes froze/locked up the other day not fully. the "gets hot then fully locked."
But even after some cool down still had to be towed.
I've worked on brakes a bunch on my old cars trucks..
I did a bunch of reading on this, so I am not just "blind" asking this question.
just no ABS knowledge.
Brakes froze on overheating
1.) Master Cylinder well that was replaced about five years ago...
Currently the car is up on blocks and I have removed all the calipers.
well the calipers are just "hanging" as it were. so nothing touching the pads directly.
Yesterday and today turning the engine pressing the accelerator.
A lot of "clicking" and clunking (new type) from the passenger right front.
Which is the ABS actuator.
The noise only starts when I push the accelerator IE: increase rotation on the wheels.
If I push the "TOC Button" disengages tracking control the "clicking" noise from Actuator and clunking stops.
2.) Checked the Tone Rings. fine no cracks missing teeth etc.
3.) Brake pedal free play is fine.
4.) I have an Actron Auto Scanner CP9575.
No codes are shown to this problem.
maybe 2003 model doesn't show any ABS information (most likely).
With the calipers off the wheels I don't think master cylinder.
Tone Rings intact.
No way to analyze sensors of ABS system with Actron.
The ABS light does not come on except after extensive "testing,"
that is it doesn't automatically come on.
Thanks a bunch group.
Mar 2, 2021 at 11:02 AM (Merged)
ROBKAYAKFISHINGGUY
I took out the ABS fuses. now no more noise from the ABS Actuator.
I've now noticed a grind/noise from left rear.. the other wheels spin freely when in drive.. this one does not.
Original problem front brakes freeze may have been caused by free play in stop light switch as it had come loose the day before.. and I probably took out the correct free play.. thus the master cylinder not resetting when I headed to work the next morning.
Obviously will be checking out problem rear wheel.. to get that sorted out.
Old car probably never had wheel bearing replaced..
ROBKAYAKFISHINGGUY
Well it looks like the original problem was caused by my adjusting the stop light and free play in the brake pedal the night before the problem started.
The rear right grinding, as I had removed the calipers on all wheels for testing.
the "plate" (sorry I'm tired now) that you remove to access the inside of the wheel where the parking brake drums are.
The two small Phillips head screws that hold it in place were not there. so it was moving off as the wheel spun and must have been grinding on the parking brake drums.
As I am not the original owner. but have the vehicle for 9 years. I had not worked on that area except for replacing the disk brake pads. not investigating those Phillip head screws that hold the plate to the unit.
Well I learned a lot along the way. gave the brakes a good flush clearing out some old junk..
Cheers, hope some of this helps other people. :-)
JOETECHPRO
  • 705 POSTS
Hey ROBKAYAKFISHINGGUY,
Thank you for posting about your issue. It will help others in a similar situation.
So you had over adjusted the brake pedal free play which caused your brakes to bind?
Sounds like you have found the problem and got it figured out on your own.
Excellent work!
If you do have any further questions please don't hesitate to ask.
Regards, Joe
MILLY99
I recently had my front break pads and rotors replaced. There was some squeaking, I went back and had the garage check, all was okay. Wagner pads sometimes make this noise...Today my break light and battery light came on...then my ABS light, My Radio started to cut in and out and went off and my air bag light came on...
Any thoughts on this problem??
Mar 2, 2021 at 11:03 AM (Merged)
CARADIODOC
  • 34,306 POSTS
Have the charging system tested. Chances are the generator has failed. That results in low system voltage and the battery light turning on because it's not being recharged as you drive. The anti-lock brake light is on because the system needs a lot of current to do its thing, and it can't do that when system voltage is low. Circuits in the radio also start to shut down with low voltage. Fix the charging system and the other stuff will work. By now though you'll find the engine probably won't crank fast enough to start. You'll need to recharge the battery first for an hour on a slow rate. That should allow you enough time to drive to repair shop.
