Thanks for your response.
I have checked and DOUBLE CHECKED for any object that looks like a test port on the fuel rail close to the induction coil which looks similar to the "Fuel Rail Test Port" shown on the last diagram that you sent me. There is NOTHING other than the object that I described to you in my last posting and it is located in EXACTLY the same location as the object that was shown to be the "Fuel Rail Test Port" in your diagram.
The object looks like a miniature top hat and it is attached to and covering a projection with an opening on the fuel rail. It appears to be some form of a dust cover. It is attached to the projection by about 4 tabs at the bottom of the hat. It appears possible to open the tabs and remove the hat like object. It is made of aluminium or other non-ferrous metal since a magnet does not get attracted to it. It is shiny metallic white in colour. It is smooth on the outside and has no knurling (to provide a grip) on it unlike the usual dust covers for Schrader valves.
Its dimensions are approximately as follows:
Diameter of the top of the hat: 12 to 14 millimetres (mm)
Diameter of the rim of the hat: 20 mm
Total height of the hat including rim: 12 to 14 mm.
I hope the above gives you an idea of what the object looks like. I will try to send you a photograph or a diagram as soon as possible. Meanwhile, the above information may provide some food for thought.
I hope to hear from you soon.
Regards.
Kabeer Sayeed
Mar 9, 2016 at 12:33 PM
