for the 1.6L engine its 3 passes, 26 Ft Lbs then 41 , then 52.
for the 2.0L DOHC engine, its a bit different. you will have 6 total steps. bolts 1-10 will be tightend as follows:
39 Ft Lbs, then 61, then FULLY loosen bolts, tighten again to 39 then a second pass to 61.
final bolt 11 will be tighten only once to 76 Ft. Lbs.
Mar 19, 2010 at 11:45 PM
