Engine Mechanical problem
1998 Geo Tracker 4 cyl Two Wheel Drive Automatic
I believe it's a 1.6 4 cylinder. You can start it and let it idle. For the first 10 minutes or so it is just fine then it develops a pretty good oil leak in the front of the engine where the oil pan lip and timing cover meet..Any way that's where it appears to be leaking...Major job to fix?? and possible problem scenario ??
Dec 27, 2008 at 3:39 PM
