i am helping a friend with a problem that originally started after being ran hot .we pulled the engine,tore it down and decided to rebuild comletely.machine work done by very reputable shop,name brand parts,after assembly and install would not start.made al necessary checks,found no comp. found leaking by valves.removed head rechecked by machine shop,replaced head timed and valves adj. as book showed.still no compression,double checked cam timing,lash,etc.the book i am using is a clymer,is there possibly a misprint
Nov 6, 2009 at 7:50 PM
