1996 Geo Tracker fuel hose
1996 GEO TRACKER
LSOROCHMAN
Engine Performance problem
1996 Geo Tracker 4 cyl Four Wheel Drive Automatic 87k miles
Ihave a fuel leak just before the fuel filter the fuel hose has a banjo fitting on one end and a fitting on the other my dealer said the cost of the part is $170 for this hose is there a aftermarket hose available that you might know of ??
Thank you
Aug 4, 2009 at 10:17 AM
DANAUTHIER
  • 156 POSTS
Check with your local parts store, there may be a repair end that will work, but most likely there is not a direct fit repir part....be sure to ask though.
You might also try doing a search for Tracker repair parts.
The Geo Tracker and the Suzuzki Sidekick of the same year are the same vehicle, you could check with a suzuki dealer and see how much they want for the part, when you have a colaborative vehicle like yours, the other dealers retail prive is sometimes lower (or sometimes higher, so be sure to check both)
Dan
Aug 9, 2009 at 10:54 PM
