1992 Geo Tracker engine timing
1992 GEO TRACKER
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
KATO77
im changing an timing belt on an 92 tracker i lined up thr timing marks on the cam sprocket but the crankshaft wont turn when i try to turn it to line it up with the timing mark.
Oct 14, 2008 at 9:09 PM
DOCFIXIT
  • 18,828 POSTS
Did belt break while driving? Crank should turn by placeing a socket &ratchet on bolt. If is does not move something in engine is bad wrong.
Oct 15, 2008 at 9:42 AM
