Engine shutting off randomly when i slow down to a stop
1995 GEO PRIZM
120,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JEFF FITZGERALD
Changed battery, spark plugs and wires, fuel filter. Car always ran fine, then its started shutting off and idling weird lately when coming to a stop. Does not do it all the time. Son drives to school fifteen minutes each way every day no problem, have to make a longer trip then car messes up. Either i let the car rest or rev it up let the idle settle then it runs fine again.
Oct 30, 2017 at 11:40 AM
KHLOW2008
  • 41,814 POSTS
When battery is disconnected the memory of the ECM learned value is erased. It most probably is the idling system running erratically. Have the throttle cleaned and retest.
Oct 31, 2017 at 2:25 AM
JEFF FITZGERALD
Car was having issues before i changed battery and fuel filter. The car runs fine until it warms up about a half hour or so then car starts to sputter and shuts off. But it is random when it happens.
Oct 31, 2017 at 2:56 AM
KHLOW2008
  • 41,814 POSTS
Is the Malfunction Indicator Light showing?
Have you ever had vehicle scanned for trouble codes?
I would still recommend getting the throttle body cleaned if it had not be done before.
Nov 1, 2017 at 7:20 AM
