2000 Geo Prizm check engine light on
2000 GEO PRIZM
133,300 MILES • 4 CYL • FWD • MANUAL
EFIGUEROA
check engine light is on...the code says it is the evap control.My Ac does not work.Is the evap control part of my AC?if so...is it costly to repair?
Jun 26, 2008 at 5:53 PM
MMPRINCE4000
  • 8,548 POSTS
Make sure the gas cap is on tight and sealing properly.
When you turn the AC on listen to make sure the clutch is engaging, it may have a leak and needs recharging/seals replaced.
Jul 31, 2008 at 9:18 AM
