1997 Geo Prizm rack and pinion
1997 GEO PRIZM
139,000 MILES • 4 CYL • FWD • AUTOMATIC
YCHIQUETE
I was told I needs to replace the power steering rack and pinion. I don't have the money right now, so what is the worse that would happen if I still drive it.
Tahnks
Oct 20, 2009 at 5:49 PM
MMPRINCE4000
  • 8,548 POSTS
Generally the rack goes bad, excessive clearence causing excessive play.
This would cause the steering to be loose.
Worst case would be a rack tooth break and loss of steering.
But is depends on what is wrong, rack, pinion, or inner tie rod, case leaking. In any case, I would repair ASAP, and not drive on freeway or at any speed above 40.
Oct 21, 2009 at 8:24 AM
