I believe the problem is the speed sensor. I found what i believe to be the variable speed sensor on the transfer case. It has one small bolt that i removed but I found that it has two wires that run down into the transfer case and are connected to something in the case. Several questions here. Is this the variable speed sensor or something like the knock sensor? It seems as though I can reach the rest of the vss thru the transmission pan, is that true?. I am even in close to the problem or should I be looking else where for my speedometer problem fixes. The sensor that I am referring to is on top the the transmission cased near the transmission mount.
Apr 22, 2010 at 5:53 AM
