1994 Geo Prizm Heater Core problem
1994 GEO PRIZM
212,000 MILES • 4 CYL • 2WD • AUTOMATIC
MCDA1953
I recently installed a new head with all new hoses, thermostat, radiator etc.. Before the heater would not heat at engine idle. Worked ok on the road. Now it doesn't heat at all. I checked the input and output ports on the firewall. I do have hot water going into the heater core and returning. I also tried running water both ways thru the heater core with a garden hose. It runs thru clear and clean. There are no leaks at all. Any idea what might be the problem? Your thoughts will be greatly appreciated.
Thanks
Nov 10, 2010 at 11:48 AM
DOCFIXIT
  • 18,828 POSTS
Blend door not directing air flow through core
Nov 10, 2010 at 12:03 PM
MCDA1953
Thanks that fixed the problem. I really appreciate it.
Nov 14, 2010 at 11:42 PM
