1994 Geo Prizm bRAKES
1994 GEO PRIZM
59,300 MILES • 6 CYL • FWD • AUTOMATIC
PENNIE43
WHEN I WAS DRIVEING THE CAR JUST STOPPED.i DROVE A LITTLE FURTHER TO GET OFF THE ROAD AND IT STOPPE,i PUT IT INTO REVERSE AND IT WENT A LITTLE WAYS AND STOPPED.COULD THE BRAKES BE LOCKING UP?
Jun 1, 2009 at 10:50 AM
MMPRINCE4000
  • 8,548 POSTS
Raise front end, put on stands, if brake caliper has siezed, wheel will not turn, otherwise:
Toyota's use a seperate lubricant supply for the trans. and the differential (where axle goes into trans).
Raise car, put on stands. Inspect the axle seals, if leaking or signs of leaking, there is a good chance the differential is out of fluid and siezing.
There should be two drain plugs, one for trans and one for differential. The differential plug is to the rear of trans plug.
You will most likely have to get trans. removed and repaired. I am not sure if just the differential can be fixed, most likely you will have to get entire trans rebuild, or get a used trans from junk yard.
Jun 2, 2009 at 7:24 AM
