1994 Geo Prizm 2 loud booms from front end
1994 GEO PRIZM
201,000 MILES • 4 CYL • FWD • AUTOMATIC
GEOPRISM1994
Recently, my son was driving the car referenced above. The front end made loud noises and the car locked up and would not shift into gear. After two days, I had it towed to repair shop and it started shifting and working again. The repair shop could not determine the problem, since it was working. I picked up the car today and test drove it all day. Once it warmed up after driving it frequently, the front end made two loud booms and it sounded like something was going to fall out. I immediately parked the car and left it. The gears did not lock up. I'm not sure if it is transmission, fuel filter, or what the problem could be. Is there any type of repair shop that can run a diagnostic on a 1994 Geo Prizm? Any ideas?
Jul 2, 2009 at 10:39 PM
MMPRINCE4000
  • 8,548 POSTS
Check the differential. Look under the car and if you see two drain plugs, one for trans and one behind it, that is differential. It is low or out of fluid and does not get lubricant from trans.
Jul 3, 2009 at 7:14 AM
