1993 Geo Prizm no fuel in cyl #2
1993 GEO PRIZM
180,000 MILES • 4 CYL • FWD • AUTOMATIC
JROSE361
car was misfireing found that #2 was it
check spark-good check injector pulse -good switched injector plug with cyl #1 and #2 and still misfired on #2
replaced #2 fuel injector with a new one
still misfireing, check for compression good check everything can not find out why we are not getting fuel into cyl #2
any help
Jan 16, 2010 at 4:05 PM
Check and test the camshaft position sensor
Jan 17, 2010 at 6:23 AM
JROSE361
i dont think that would only effeict one cylinder
i can un-plug the injectors and see the engine mis fire
and when i un-plug #2 nothing happens before and after i changed the fuel injector
Jan 17, 2010 at 12:42 PM
You good spark and compression to the no.2 the injector was replaced with a new one and still not schronizing-could be a wiring problem or the driver from the computer-You got a tricky situation
Jan 17, 2010 at 12:48 PM
