Engine Performance problem
1997 Geo Metro 4 cyl Front Wheel Drive Automatic
i am working on a 97 geo metro lsi with a p0400 code that refuses to go away. before i got the car the egr valve,the vacuum modulator valve,and the pair of solenoids under the modulator valve had been replaced with new from the dealer parts. i noticed the egr valve doesnt open under wide open throttle,in gear or in neutral(after engine is warmed up).i can open the egr valve with a vacuum pump and the engine stumbles.the solenoid that controls the egr has vacuum to it but doesnt open under throttle, however i can ground one of the wires to that solenoid and it clicks open and the egr opens. i have replaced a few vacuum lines that were damaged. i have the usual question......what now? haha, what controls the solenoid? the pcm? thanks for your help in advance.
Apr 7, 2010 at 2:21 PM
