1995 Geo Metro Radiator fan problem
1995 GEO METRO
MAGIC.SEAN
Electrical problem
1995 Geo Metro
My radiator fan does not seem to be working right, as it does not start spinning when I start my engine.
The radiator fan will rotate when connected directly to the battery or when I disconnect the fan switch.
I saw an answer to a similar question which said to check for a faulty radiator cap, but the cap feels like it is snug and secure, so I followed the hose leading from the cap and it is connected to the coolant resevior, however the resevior is cracked near the top above the fill line (from a recent accident I assume).
Nov 21, 2008 at 6:49 PM
Check the fan relay, coolant temperature sensor and also the computer control of the relay.
Nov 21, 2008 at 7:16 PM
MAGIC.SEAN
Thanks for the quick turn-around for the answer!
I checked the fan relay by switching it with like spec'ed relays for other features (Lights 1 and Lights 2) and the lights and fan behavior is consistant no matter which relay is placed where.
The fan switch i disconnected is located at the end of the radiator hose where it enter the engine (unser the distributor), I think that is the coolant temp switch, is that the same as the sensor? Anyway, when I disconnect it the fan starts right up.
I haven't come across any relay computer control for the Geo Metro 3 cyl. but I willl do some research in that direction.
Nov 21, 2008 at 7:46 PM
