1994 Geo Metro ELECTRONIC CONTROL MODULE
1994 GEO METRO
RANDYEGG
Electrical problem
1994 Geo Metro Two Wheel Drive Manual 200000 miles
1994 3 CYLINDER NEW STYLE COIL, DISTRIBUTOR WITH ONLY THE PICK UP COIL. SO MY QUESTION IS: I SHOULD HAVE AN IGNITOR LOCATED ON THE FIREWALL, BUT I HAVE NONE. WHERE ELSE COULD IT BE? PURCHAED CAR USED NEVER HAS RUN YET. NO SPARK FROM COIL, BUT HAS POWER TO COIL. IGNITOR/SHOULD BE THE ELECTRONIC CONTOL MODULE.THIS IS WHAT I AM LOOKING FOR.
Aug 27, 2008 at 7:52 PM
Try the ignitor inside the engine compartment fuse/relay block test out okay -check the crank angle sensor in the distributor
Aug 27, 2008 at 8:18 PM
