Engine Performance problem
1992 Geo Metro Front Wheel Drive Manual 90000 miles
I recently bought a 1992 Geo Metro. It has a 3 cyl motor. The fuel pump is brand new as well as the fuel filter. It also has a new timing belt! When the car idles sometimes it will idle fine then other times it will try to die. The main problem is when you get it driving at about 20 mph or right around there it will stall or lurch. Then it will pick back up again the do it again. Seems that for some reason it is cutting either power or fuel to the motor! I have removed the battery and it made no difference. But when I went to plug the battery back in it puts the motor under a load at idle. Im stumped.
May 31, 2008 at 4:41 PM
